Problem in serial port code
1. I have made a serial port Vi which I have attached.
2. MCU on other side is sending data on USB at speed of  921600 bps.
3. VI sends "S" byte to mark the send & then MCU send 43202 bytes to the system.
4. Problem is after 3 or 4 iterations, there is some error. Sometime like less bytes received, some times error code returned is zero. For zero code what is error?
Soimetime error is overrun error?
5. However if I send data n hyperterminal or realterm I receive corect data.,
(3,744 Views)
Accepted by topic author Vindhyachal.Takniki
Disable TermChar for messages of defined byte count…
(It's an input of VISAConfigureSerialPort!)
(3,741 Views)
Thanks @GerdW solved the problem.
(3,686 Views)
