Problem in running exe
I have created a exe in LabView8.0.When i try to run that exe in the pc where LabView is not installed i am getting the
message like this "Application requires a version 8.0(or compatible)LabView Run Time Engine.Please contact the vendor of application to correct this problem"
Please help me
Thanks & Regards
Meenatchi
(3,020 Views)
You can download the runtime engine from the following link:
(make sure you get the 85MB version)
You can also create an installer for your application that includes the runtime engine.
Message Edited by altenbach on 08-27-2007 10:27 PM
(3,019 Views)
Have i to install the runtime engine in the pc where i am going to run the created exe?
i have created the exe in my pc and having the run time engine also.I am trying to run that exe in some other pc.
can u tell me the pc where i am going to run the exe should also have the run time engine?
(3,013 Views)
Yes, the machines on which you run your executable need the run-time engine installed.
(3,009 Views)
