Problem in retrieving record from database
Hello friends,
                      I have a database (mdb / SQL) in which I am writing date/time and 4 other columns, During retrieving record I expect only date from user and retrieve records using select query, I am able to retrieve the record by giving date / time but when I am providing only date then there is no record coming out.
Thanks.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,703 Views)
What is the SQL query that you are using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,695 Views)
For reading one record
select * from Scaned_Report where col1 = #11:20:45 27-07-2013#
For reading multiple records
select * from Scaned_Report where col1 between #27-07-2013 09:30:20# and #27-07-2013 10:00:00#
Done in mdb database. I want to retrive by mentioning only date.
--Ranjeet
(3,691 Views)
In Jet there is no real clean way of selecting all the records for a specific day. The best solution seems to be to use the "between" clause and for the time portions specify "00:00:00" and "23:59:59", respectively.
Mike...
LabVIEW Champion
(3,685 Views)
I already did that.I chose the time from 6AM to 6PM. becasue this is better as per my requirement.
--Ranjeet
(3,629 Views)
Your database screenshot shows a date format different from those used in queries you posted.
Jim
(3,613 Views)
