Problem in reading data from UDP
I am using NI 7352 motion controller card,
I am communicating two PC's by using UDP protocol,I am reading a text file in remote system  which contains series of points and retrieving that points one after the other with some fixed delay and sending that points to local system.The local sytem reads that points and the position feedback will be given which is to be dispalyed in both  local and remote system .I am able to dispaly all the positions  in local but not in  remote,  only the last point is getting updated in remote system, But when Iam giving single point (without text file) through remote system to local system the position feedback  is getting  updated in both local & remote system also.
(2,605 Views)
You need to tie the screw on your backcover of your PC a little!
Honestly, how do you expect anyone to be able to help you with this information? Without seeing the code it could be anything, including the moon phase, that causes this!
Rolf Kalbermatter  My Blog
(2,601 Views)
