Problem in plotting data read from Visa
Hi Guys,
I am working on a labview code to read data from atmega 32 microcontroller through USB. But I am facing a problem. whenever the data crosses form +ve voltage to -ve or vise versa, the data point is lost and instead a positvie or negative spike occurs. I have tested my circuit on the CRO and no such peak exists. Thus I think the problem lies with the way I am reading the data. The (digital) hex data read, is converted to analog as per the "result representation" of atmega manual. Please find my VI, read waveform and the result representation attached. Please let me know if anyone finds my mistake
Thanks a lot!!
Have a great weekend!
(3,276 Views)
When you have a problem reading data from an Instrument, one useful strategy is to simply collect and "look at" the data coming in from the Instrument.  Sometimes the problems are as simple as a mixup in reading, a mixup in interpretation (you get 12 bit numbers stored in offset binary and you need to convert them to 16-bit "ordinary" binary), or something similar.
A very common error when reading Serial Data is to use "Bytes at Port" to control the VISA reads, which can result in strange happenings.  I notice you have set the "Use Termination Character" input, which means you expect your Instrument to send you a complete string.  Well, that's what you want to do!  Here's my re-write of of your code (with details omitted):VISA InputVISA Input.
Some obvious points (which are not entirely trivial):
  • Error Line and VISA Line "run through it" and are kept straight.  Error Out is named "Error Out".
  • Configure Serial Port inputs that are Defaults (except for critical Enable Termination Character) are left blank.  I notice you have an unusually large Timeout (2.5 minutes!).
  • VISA Buffer Size not used -- default Buffer of 4096 should not put a strain on your memory resources!
  • Key step in inside the Loop.  Do a VISA Read of more characters than you ever expect in a string.  This returns you an "entire" VISA Read (or else a TimeOut if the Instrument stops for some reason).  So when the VISA Read returns, you have an entire String to parse, and hence are much less likely to make parsing errors.
  • Note that there are no Timing modules inside the loop -- the Loop is being clocked by your Instrument, looping once per data "chunk" (I'm assuming the data comes in slower than the LabVIEW code to process it -- if you have too much processing code inside the loop, use a Producer/Consumer Design to move the processing to a Consumer Loop).
If you run this code with your Instrument, you can bring Data Read out through an Indexing Tunnel and get an Array of Strings showing just what your Instrument is sending you.  If you are having parsing difficulties, sending us a sample of these data would help us suggest what might be going astray in your parse.
(3,231 Views)
Hi Bob,
Thanks for getting back to me.
The problems was with interpreting the received data. I removed the bytes at port control. As you suggested I tried reading the whole data at once but that was somehow causing more problems. It was unable to read the negative values when the "Visa read" byte count was 1000. Thus I tried reducing the byte count to 2 and I was able to read the exact expected data. Only down side to this was it takes more time, but it is not a huge concern in my case.
- I cleared the error and visa lines
- I disabled the termination character as I was not using it.
- The timeout is high because my data is transferred as a whole after the experiment is complete.
- I have tried using the Visa buffer size considering max data points I want to read instead of max available size.
- As I mentioned above, Visa read of more characters was causing more problems
- I also removed the timing module
Thanks a lot for your help!
(3,214 Views)
@pratikpade wrote:
Hi Bob,
It seems to me that there are still fundamental things that you aren't understanding about the communications protocols, or you wouldn't have to kludge the thing so badly.  All this "buffer this" and "max data that" shouldn't really be necessary if you truly understand how to communicate with the instrument.  What you are coding is very fragile; communications protocols (usually) aren't.
The closer you are to truly understanding, the more smoothly and "automatic" things should get.
Bill
CLD
(Mid-Level minion.)
(3,209 Views)
How EXACTLY are you sending the data through out of the microcontroller?  I am specifically referring to the message protocol you implemented.  I really hope you are not just spitting out the raw 16 bits because you will run into weird synchronization issues.  Once we have the protocol figured out, then we can talk about fixing your code.
(3,191 Views)
