Problem in ni labview interface simulation toolkit
HI
I use labview7.1,ni labview interface simulation toolkit v3.02,matlab R2006a,visual c++6 but I have a error when I use built in matlab.My file name is "a.mdl"
Can you help me?
*******************ERROR******
Microsoft (R) Program Maintenance Utility   Version 6.00.9782.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
    mkdir C:\SimulationInterfaceToolkit\ModelInterface\\tmw\lib
        1 file(s) copied.
        1 file(s) copied.
### Compiling the source a
    cl -Ot  -DUSE_RTMODEL -DNI_ROOTMODEL_a -DMODEL=a -DRT -DNUMST=1  -DTID01EQ=0 -DNCSTATES=0  -DMT=0 -DHAVESTDIO -DNATIONAL_INSTRUMENTS_SIT   -c -W3 -DCRTAPI1=_cdecl -DCRTAPI2=_cdecl -nologo -D_X86_=1 -D_WINNT -D_WIN32_WINNT=0x0400 -D_WIN32_IE=0x0300 -DWINVER=0x0400 -DWIN32  -D_WIN32 -D_MT -D_DLL -MD -DRVE a.c
a.c
fatal error C1900: Il mismatch between 'P1' version '19991026' and 'P2' version '19970710'
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
C:\Program Files\MATLAB\R2006a\work\a_nidll_rtw>echo The make command returned an error of 2
C:\Program Files\MATLAB\R2006a\work\a_nidll_rtw>An_error_occurred_during_the_call_to_make
'An_error_occurred_during_the_call_to_make' is not recognized as an internal or external command,
operable program or batch file.
(3,082 Views)
(3,074 Views)
