Problem in implementing Logic
No I never read any such examples. I tried as you suggested but didnt suceeded
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 14
(833 Views)
This is what you are missing.
Message 12 of 14
(831 Views)
Ranjeet,
You've been around the forums long enough that you should've have seen build array and shift registers enough times to have been able to figure this out.
Message 13 of 14
(798 Views)
You don't really need to format the number every iteration, only when it is actually needed. Since we now have a case structure, we can also eliminate the select node. Here's a quick draft.
(Note that this requires the input array to be sorted as you said. If it is not, simply insert a "sort array" in the right place i.e. before the first wire branch of the input array.)
If all array elements are guaranteed to be single character strings, there is an even simpler solution... try it. 😉
Message 14 of 14
(787 Views)
