Problem in channel selection of kithely2010 using usb to gpib adapter(aglient 82357A)
im using aglient 82357A (usb to gpib)adapter with kithlay 2010. labview detect the adapter,
i have the problem while channel selection of kithley 2010 using gpib....how can i make channel selection VI ???? any one plz help me in this matter
(3,746 Views)
You should find what you need (Keithley 2010 manual with GPIB commands) here :
http://www.keithley.com/products/dmm/dmms/?path=2010/Documents#4 (Model 2010 quick reference guide rev. B => p 36)
For you, it should be something like that (the following lines in bold should be enough) :
:ROUTe:MULTiple:OPEN <list> //Open specified channels (1 to 11)
:ROUTe:SCAN <list> //Specify internal scan list (1-10 by default)
:ROUTe:SCAN:EXTernal <list> //Specify external scan list (1-10 by default)
:ROUTe:SCAN:LSELect <name> //Select scan operation (INTernal, EXTernal, or NONE)
To have an idea about the way you can send those commands, you can have a look at examples VIs : GPIB-VISA.vi and LABVIEW-GPIB.vi
Hope this helps...
(3,734 Views)
from where i can see these commands
im using the vi....which is attached...but  the send messege vi is missed
(3,716 Views)
sorry the above posted attachement is for serial...im infact using this
(3,713 Views)
thanks a lot 4 ur copration
(3,697 Views)
