Problem in call library function
I encountered some problems when using call library function node.
After i select the path in configuration of call library function node, an error message is shown as 1st attachment.
After i tick and the specified path on diagram, link the path name to the node, and run the program. Another error message is shown as 2nd attachment.
Is my dll file got problem? Or i have done a wrong setting?
Here i have attached my dll file.
The dll file is built by Microsoft Visual Studio 2008.
Please kindly advise.
Thank you.
(2,750 Views)
It seems to be compiled for WinCE. Assumed that you have Win2000/XP/Vista/7. Check your MSVC build settings.
Andrey.
(2,738 Views)
The dll is compiled for winxp. May i know what kind of build setting i should check in MSVC?
Thanks.
(2,709 Views)
