Problem in CAN
I am using NI PCMCIA CAN card.I have connected the CAN Card to my DUT.I will be sending messages from DUT every 400ms.
I have executed the sample code Transmit Receive Same Port.vi.In that i will be getting same message at every 1ms delay.
I have attached the snapshot of that screen. Can u tell me what is the problem?
Regards
Meenatchi
(3,198 Views)
Waht is the problem that u r facing????
(3,075 Views)
So if I get what you are saying, you want to transmit every 400 ms, and get a response back.  The DUT is spamming the bus currently around every ms.  Since I have no clue what your DUT is, I don't know if this is standard operating for it, you may want to find out.  For a write every 400ms, if you want to read data back, I suggest you look at the vi I posted.  It will read all of the pending frames and return the data in an array.  Then you can use the Arbitration ID you expect to recieve as a filter to find the frame you want.  That way you don't read the data from one of the messages sent every ms instead.
Does this help?
(3,062 Views)
