Problem generating and aquiring 10Hz signal with 6024E
Hi I am working on a Bodeplotter, but I have some problems.
I am trying to generate and aquire 10Hz.
I found a vi in the forum that has an RC lowpass filter between DAC0 and ACH0.
I've also coupled the output directly to ACH2, that is DAC0-> ACH2
I am using Aquisition board BNC2120 with a PCMCIA card 6024E.
How high up in frequency should I be able to go with my hardware, if I am going to use one output and one input, in my Bodeplotter. I would like to be able go from 0,01Hz to 10kHz, at least up to 100Hz.
I also don't understand how to play with "samples to write" and "rate" in the output configuaration of the daq.
As well as "samples to read" and "rate" in the input configuration of the daq.
Do these pairs have to be equal in both the output configuration and the input configuration?
Kindest regards,
Lasse
Message 1 of 1
(2,259 Views)
