Problem distributing LabVIEW Linux Application
I have....#1 LabVIEW 6.1 for Linux (full development system), #2 Labview linux application builder
I created application using "build application or shared library option".
Additional info:
# I do have LabVIEW run-Time Engine for Linux installed
# I do have application builder installed from other CD.
# It's Redhat Linux 8.0
# My application's folder s different from where Run-Time engine is installed.
# PROBLEM 1
But I can't even run it on even the SAME computer.
(I tried double clicliking AND running it (by name) thru xterm)
# PROBLEM 2
#When I want to distribute it for customer, how do I do it?
Sandeep
sandeepvd@hotmail.com
(2,628 Views)
In article <506500000008000000816C0000-1031838699000@exchange.ni.com>,
"Sandeep" wrote:
> Additional info:
> # I do have LabVIEW run-Time Engine for Linux installed # I do have
> application builder installed from other CD. # It's Redhat Linux 8.0 #
> installed.
I don't believe this should be an issue
> # PROBLEM 1
> But I can't even run it on even the SAME computer. (I tried double
I just made simple executable with LV 6i for Linux. I ran ldd on the it
and it shows that it's linked to:
libdl.so
libpthread.so
libc.so
ld-linux.so
Some of these libraries may be different for LV 6.1 but what you're really
looking for is someth
ing like "library not found". That would be a sign
that your run-time engine installation got fouled up, the libraries
haven't been placed in the right directories, or ldconfig needs to be run.
One thing I hate about the LV executable in Linux is that the controls
always come out messed up. Mine lose their 3D appearance allong with
most of their borders. Luckily I don't have any clients that need Linux
apps yet.
> # PROBLEM 2
I'm not sure but since you're using Redhat I'll bet there's some RPM based
installation builder that you can use. I use Slackware so I would
probably distribute my applications in the tgz or tar.gz formats.
Perhaps there's some sort of GPL installation builder out there...?
> Sandeep
I'll be visiting relatives for most of this week but keep the group
updated on your progress.
- Kevin
(2,628 Views)
