Problem creating an installer - distribution needed
Hello
I need to create a standalone application (.exe) but am having a problem creating the installer. During the build process (after building the exe and configuring the installer's settings) I get a message saying:
"Distributions Needed, Some of the products you selected, or their dependencies, are in distributions that are unavailable. To include the products you selected, the following distributions are needed. NI-DAQmx 9.2.1"
A screen print of the message is attached.
By expanding the 'software' tab in the left hand column of MAX I see that NI-DAQmx 9.2.1. is on the list of software. So, I do not understand why the installer says that it is unavailable. I have also attached a screen print of the installed software.
Can anyone suggest what I can do to fix this please?
(2,496 Views)
You need the actual installer, not the files that were installed from it. Get your driver DVD that came with LabVIEW.
(2,490 Views)
