Problem connecting to a remote oracle database using labsql
Hi all,
I'm trying to connect to a remote oracle 9i database using Labsql but I get "provider cannot be found"-error.
Oracle odbc driver is installed and tested so the connection should be ok.
This is my first time with oracle database (I prefer mysql) so the connection string
can be faulty... help?
Thanks for advance
PS. I'm using windows 7 64-bit with Labview 2011
(3,373 Views)
(3,369 Views)
I'm using this connection string at the moment:
Provider=OraOLEDB.Oracle;Data Source=MyOracleDB;User Id=myUsername;Password=myPassword;
It gives me the "provider cannot be found"-error. The connection string should be right(?).
(3,356 Views)
That connection string that you are using is NOT for ODBC driver.
You can download the OLEDB driver from Oracle's website.
(3,347 Views)
Looks like my problem wasn't the connection string after all.
After trying connection string with Microsoft oracle driver I got "architecture mismatch"-error,
did some searching and found this:
http://digital.ni.com/public.nsf/allkb/E7984C0DA0F0E65086257694005B4CB7
Probably after installing 32-bit version of oracle client and creating the dsn-connection
using 32-bit version of odbc manager everything should work.
(3,334 Views)
