Problem about data in "real time"
Hi steve,
Sorry, I wasn't working the last days.
I tried to put a structure around the "write to measurement file" as you told me in your last message. But it doesn't work. Something is strange, I got 0 error but the file isn't created.
To be more specific, if in the "write to measurement files" settings, I tick "ask the users to choose a file", i will have the answer and the file is created after, but I can't choose when exactly. So it's a problem. And in addition, I still got the same data in all lanes, as before.
But when I don't tick this option, and chose just "save in a file" the file isn't created at all...
Message 51 of 58
(1,250 Views)
About the error "5", I don't understand too...
I tried to change the location of the file, the name, etc. And nothing works. I never seen this error before, and finally I did a lot of test and saved lot's of file before this part of the code. So I don't understand why now, I got this error, cause I got exactly the same settings than before.
Message 52 of 58
(1,249 Views)
If you zip up a copy like you did before, I will look at it.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 53 of 58
(1,244 Views)
I hope that I'll send everything :s
I hope that you will understand what's wrong with it ...
Thank you, again.
Maxime
Message 54 of 58
(1,240 Views)
It looks like your vi has been drinking Smiley Wink
The first thing I see is you used a while loop instead of a case structure around the Express vi.
The little true/false constant should be wire to the case selector. (Use to turn on/off logging)
You wont need the second stop button.
I'll do some more checking.
Message 55 of 58
(1,236 Views)
Oh, there is an enable input on the Express vi.
There is no need for any extra structure.
Just a true/false connected to the enable input.
(The second one down on the left side.)
Message 56 of 58
(1,233 Views)
When you are talking about the "express vi" I don't understand what is this 😮
This is the VI multi task ? :s
Cause, I thought that's the block measure file, then I deleted the loop while and I put a loop condition. I don't know if you would say that... but I did it, and I got the error 5, again...
Now about the second message, I don't find the enable input ><
I got this  : ex multi tasks.PNG
But I don't know if it's what you want ><
Message 57 of 58
(1,226 Views)
Yes, I was talking about the "DAQmx Multi tasks" vi.
When I removed the while loop you added, and reset the target file,
the vi runs OK including saving the data to a file.
I am, however, using simulated hardware.
Actually I did get an error 5 once - I did have the file open, so it was expected.
Your implementation of the case structure should work. (Set a false to disable logging)
Although there is a simpler method available.
Here is the context help for the "Write to Measurement File" express vi.
Message 58 of 58
(1,187 Views)
