Problem about Microsoft.Research.Kinect.dll when use Kinect
Hi everyone,
I am trying to connect Microsoft Kinect and LabView follow this tutorial https://forums.ni.com/t5/Example-Code/Kinect-LabVIEW-Interface-Using-Microsoft-Kinect-API/ta-p/39961...
I'm using LabView 2010, Vision 2010, OpenNI and PrimeSense. However when I opened the project follow the tutorial above, the notice about Microsoft.Research.Kinect.dll appeared (I added the screen below). If possible, please consider it and help me overcome this problem
Thank you for any insight
I'm looking forward to hearing from you
Mina.
---Let it works---
(8,246 Views)
I think there is a similar post about this problem here: https://forums.ni.com/t5/LabVIEW/Using-the-Microsoft-Kinect-for-Position-Tracking-in-LabVIEW/m-p/173...
It looks like you may be on a different version of SDK than the example program you're trying to run, which was written using Kinect's SDK version 1.0.0.11.
CLD Certified
(8,231 Views)
Thank you so much for your help,
However when I tried to run program, the notice like this appeared (I attached screenshot below) So I wonder whether the error didn't come from the conflict of version of SKD problem. In addition, I'm using window xp, is it suitable for this project?
Please let me know if any clarification is needed of my issue.
I'm looking forward to hearing from you.
Mina
---Let it works---
(8,224 Views)
I still believe that error is caused by the fact that you're system was not able to find the correct .dll, as your original post indicated. My guess is that the file path to the .dll changed with the newer version of SDK.
The constructor node that is throwing the error actually references the missing file. You can try to change the reference of that constructor node to where the .dll is on your machine or you can try and set up the older version of SDK.
Either one should get you up and running. (look at step one under troubleshooting on the example page you linked)
CLD Certified
(8,208 Views)
I will install the older version of SDK and try to operate this tutorial again. Unfortunately I am using window xp, so I have to change to window 7.
Thank you so much.
Mina
---Let it works---
(8,191 Views)
I think that problem is that you are working with the set of tools for microsoft Kinect while those of OpenNI, this can generate a conflict, I have understood you need to uninstall one to work with others, check out this link
https://groups.google.com/forum/#!topic/openni-dev/Is0SvI2pfp4%5B1-25-false%5D
(5,814 Views)
