Problem With DB Insert VI
Hello Forum,
i have an strange behavior i can`t explain. I try to write some info's in a SQL Database.
If i use the SQL Execute VI it works fine, but if i use the Insert VI, that i would prefer, the error 1 occurred.
Can someone help me to get the failure?
Thanks a lot!
Tim
(1,771 Views)
A first problem is that you cannot set UniqueID since it's AUTOINCREMENT, thus automatically managed by the RDBMS. In any case, it's not a text.
Paolo
(1,752 Views)
Thanks for replying!
I would like that the first row "UniqueID" will get automatically filled out with the next UInt number by the DatabaseEngine.
But when I only insert one value, for Example the "BauteilKategorie" an error occurred.
My wish is, that i provide "BauteilKategorie" Line 2 till "Besitzer" Line 8 and the Database engine will fill out "UniqueID" automatically.
Best Regards
Tim
(1,745 Views)
