Problem: More Low Digits in String to Float conversion
The "From Exponential/Fract/Eng" String Function yields numbers
with 1% accuracy, i.e. 2 digits after the decimal point
How can I get more digits after the decimal point?
(2,944 Views)
The string conversion function is more accurate than two decimal places. Your numeric indicator may be set to display only two digits. On your front panel, right-click on the numeric indicator, goto Format & Precision and enter the desired number of Digits of Precision.
(2,944 Views)
Al S is correct. They do have more precision than that. I am attaching a very small example in which the string displays six digits of precision.
J.R. Allen
(2,944 Views)
