05-15-2007 09:41 AM
06-11-2007 04:18 AM
Hi Dai,
I didn't see any problems with DeltaV OPC server in our database. Is it really a problem to work with DataSocket? I can understand that's a little bit ennoying for you! Are the names of your variables always constant? So you could keep it the same and then configure your system once.
Keep us informed about your application or if you have questions about programmation!
06-11-2007 09:39 AM
I do not trust datasocket for this. I already tried with LBW 7.1and after something like 150 datasocket connections to DeltaV OPC, some variables do not respond anymore.
It's kinda wierd. It happens to groups off variables. Just add one more connection and a all bunch off the other connections freeze. Remove it and it comes back...
One application Engineer of NI told me at the NiDays that datasocket was not meant for so many variables and that I had to use DSC.
He said something like : "Now you know why datasocket ships with Labview and that you have to pay for DSC..."
I'll take some screenshots to explain, but later... In fact, we are going to upgrade our DeltaV to version 8 or 9 soon (currently 7.4).
Dai
12-22-2007 10:49 AM
