Problem Configuring Web Server
Hi folks,
I am using the LabVIEW 2009  Remote Panels to some experiments that I have. Everything was working fine, I have my Web Server configured correctly but suddenly it stopped working.
I got the message "Client does not have access to specified VI". I've checked the answers to this question in the forum threads, and figured out that my configuration is fine, besides the option of "VISIBLE VIS" that is disabled and grayed out(the add button, remove, and the field that have de vis avaible, time limit, etc).
I guess i have to enable it to make my server works again, but I have absolutely no clue of how to do that.
Any tips?
I attached a pic to show the problem.
(5,297 Views)
I would recomend you to go through this document, might help.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3SaCAI&l=en-US
(5,273 Views)
I've done all these things in the document, my problem consists in the "VISIBLE VIS" dialog, as you can check in my attached picture. All the buttons are disabled and grayed, and I dont know what caused this.
Thanks for the support!
(5,271 Views)
I've also read this too... My problem is that te visible vis field is disabled, so I can't input anything into it, and I don't know why this ocurred!
(5,254 Views)
I also tryied to restart Webserver configurations, and nothing changed. I guess that I'll have to reinstall Labview Smiley Embarassed
(5,253 Views)
I re-installed Labview, and it got working again.
But the problem showed up again, and I am looking for another solution that doesnt involve re-installing Labview.
Any tips?
(5,182 Views)
