Prob. with HP 34401A for RS-232 communication
Hello everyone,
I am using Labview 7.1 and my O.S is Windows XP.  I am trying to use the Hp 34401A multimeter with Labview. I have used the " HP 34401A single read example " from NI web site and the HP34401A app. available in Labview 7.1. It works fine through GPIB communication. However, when I scroll down the Visa Resource Name and choose " Com1" which I have cheked out to be the right one, it doesn't work. Both ends of the serial cord are correctly connected. I get this message :
"VISA Write dans HP34401A Control Mode.vi->HP34401A Initialize.vi->HP34401A Single Read Example.vi"
with the error number : -1073807339
I have download and installed NI-VISA Version 3.3.1 for Windows 2000/NT/XP--Includes support for LabVIEW RT and RTX
and VISA Run-time Engine Version 3.4.1 for Windows 2000/XP x64/XP
But this doesn't change anything to the problem.
I have seen on the forum that other people have had a similar problem but I haven't been able to find the correct solution.
Would anybody have an idea what else I could try? Or have a very, very, simple VI that I could try out to see if I succeed in communicating with the Hp instrument through  RS-232.
Any help would be great,
Thanks a lot,
Marc
(5,370 Views)
When I use the Serial port for communication to instruments the VISA Alias I use for COM1 is ASRL1::INSTR. Use Measurement and Automation explorer to verify the instrument is recognized on the Serial Port.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(5,360 Views)
The easiest way to verify communication is with Hyperterminal. Configure a session like the one in LabVIEW (baud rate, parity, etc.) and see if it works when you send an "*IDN?" command.
(5,359 Views)
Thank you very much to both of you for your help.
Before I try to communicate through MAX ( or Labview), do I need to install any software related to Hp 34401A so that it is recognized ?
regards,
Marc
(5,347 Views)
Not for the serial port. Unlike the GPIB, MAX cannot detect instruments connected to serial ports - it doesn't even try because there is no such thing as a standard protocol for serial instruments. All MAX will do is detect the serial port itself. You can use MAX to open a VISA session (right click on the com port) and use that instead of Hyperterminal.  It's your choice.
(5,340 Views)
Not that I know of.
Andrew Alford
(5,338 Views)
