Printing
I am trying to print signals off my VI graph, all I get is a blank graph without any signal and even the scale on the blank graph does not match what is on my VI.
Vic
Message 1 of 14
(5,003 Views)
Hi Vic,
can you show what you have so far? How do you try to print it? You can use an invoke node to get a picture of your graph and print it than.
Mike
Message 2 of 14
(4,995 Views)
Show us your code or at least the portion of the code which both refreshes / displays the image and where it prints.
You may have a race condition..  The printer is faster than the eye 😉  (At the least the print buffer).  If the print command is reached before the image was processed, you'd end up with a blank picture.
RayR
Message 3 of 14
(4,976 Views)
Hi there,
I am very new to labview, please help on the attached file. All I want is to be able to print the signals without the black background unto A4 paper.
Vic
Message 4 of 14
(4,956 Views)
Hi Mike,
Please find attached what I have done so far. I want to be able to print the signals on paper without the black background.
Vic
Message 5 of 14
(4,952 Views)
Hi Vic,
you can convert your data to dynamic or you can create a picture. See both abilities in the attached example.
Hope it helps.
Mike
Message 6 of 14
(4,943 Views)
There seems to be an error. The VI prompts me for some files e.g append VI
Message 7 of 14
(4,931 Views)
When? While loading, or while running? I use the same vi´s as you.
Mike
Message 8 of 14
(4,929 Views)
while loading
Message 9 of 14
(4,917 Views)
Hi Vic,
try this please. It is without the create picture solution. It uses only the vi´s which you use.
Hope this helps.
Mike
Message 10 of 14
(4,915 Views)
