Printing labels (barcode, datamatrix code, ...) with LabView via Codesoft
I am using LabView 2012 Professional Development System.
I could not got them from C:\Program Files\National Instruments\LabVIEW 2012 \vi.lib
NI might be no longer support this Vis or changed their names; I need to figure it out.
Thank you very much.
Message 21 of 32
(2,924 Views)
now attached in LV2012.
Now this should work. Please feedback.
Thx., Thomas.
Message 22 of 32
(2,918 Views)
Lable Print Application is working fine on Labview 2012. I really appreciate your help.
Now I have to write an application to create lables.
Thank you vrey much.
Message 23 of 32
(2,902 Views)
I'm interested to try your print label application.
The Problem is I am using labview 7.1 & labview 2010.
Could you please provide application with above labview version?
thanks in advance
Message 24 of 32
(2,805 Views)
Hello yanz,
I want to help you but at the moment I don't have access to a working LV environment.
May be in 2 weeks I can create a LV2010 version for you.
BR
Thomas.
Message 25 of 32
(2,793 Views)
Its ok, I'm happy to hear from you soon.
Message 26 of 32
(2,790 Views)
Hi Yanz,
I opened the LabelPrint2012 project and tried save to previous version for 2010. Go ahead and open it to see if this works! I don't actually have LV 2010 so I didn't test it out.
I couldn't save all the way back to version 7.1. You may be able to try that from the 2010 version or post it to the version conversion forum.
Cheers!
Message 27 of 32
(2,783 Views)
What Bout to Decode MatrixCode from Picture? without use the Vision module of course...
Message 28 of 32
(2,707 Views)
I'm a little unclear on what you're asking. Could you please rephrase and elaborate on your question?
Mike
Message 29 of 32
(2,676 Views)
I'm trying to decode a 2D bar code from Image Data/picture/file, without use Vision Module.
I'm going to install this in 4 diferent station and the licenses are to expensive.
Message 30 of 32
(2,670 Views)
