Printing in LabVIEW
Dear All,
I wrote some instrument control programs using LabVIEW and I need to
print some graphs. Have you ever done this? Can anybody help me with
some advice about printing a graphic in a "nice" format using LabVIEW?
Now I use Excel (I export a text file etc.) but it's not a very fast
solution.
Thank you,
Emil Radulescu
Drexel University,
School of Biomedical Engineering, Science and Health Systems
3141 Chestnut Street
Philadelphia, PA, 19104
emil@biomed.drexel.edu
Tel: (215) 895-1829
Fax: (215) 895-4983
(3,602 Views)
Emil Radulescu wrote:
> Dear All,
> solution.
> Thank you,
> Emil Radulescu
Emil,
One of the easiest ways to do this is to create a SubVI with just the graph
that you want to print on it. Set the Subvi to "Open when Called" "Close
afterwards"
and "Print on completion"
Now all you have to do is call this SubVI and pass the data into it. It will
print
it's front panel (the graph) and close itself.
Kevin Kent
(3,602 Views)
Another way to print is to use the VI-Invoke Node with the VI reference. There
you can print the "Documentation" of the current VI, for example only the
front panel. You can hide uninteresting things on the front panel during
the "printing" and you will so only get i.e. a specific graph.
Hope that helps
Peter
(3,602 Views)
When I'm manipulating a graph, and get what I want on the screen, I
just hit File->print from the toolbar. It will print the screen
exactly the way it appears in front of you.
Mark
In article <39736050@newsgroups.ni.com>,
reference. There
the
during
> Hope that helps
> Peter
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,602 Views)
