Printing a waveform graph
Hi does anyone knows how to print just the wave form graph wit some sort of
printVI?
Thanks in advance,
Best Regards,
Thijs Boeree
(5,661 Views)
You can use the print.vi located in the Application Control Pallete. If you want JUST the graph then you create a VI with just the graph on its' front panel then put the print VI on the diagram with the current VI's name into it. Make sure you set entire panel to (F) this will limit the printing to only the visible area of the VI, preferably the graph...
Michael Aivaliotis
VI Shots LLC
(5,661 Views)
