Printing String
I am trying to print this string and for whatever reason when the printer starts to print the text does not show up.
for example i put in "Harold" for the string and the printer prints out a blank piece of paper
here is the code:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(5,813 Views)
also I would like to add that I am printing from a label printer so they are not normal sized pieces of paper
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(5,799 Views)
I can't open your code, since I'm still using 8.5, but I recently had a similar problem using a brother label printer.  Turns out the margins were set so big they were overlapping leaving no printable area on the label.
(5,795 Views)
so how did you fix this problem?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(5,787 Views)
Accepted by topic author Harold_Timmis
In my vi, i used the "easy text report" vi, which has a "margins" cluster input terminal at the top.  I set all margins to 0.15.
(5,783 Views)
yeah I set the margins right and it works
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(5,779 Views)
Cool, my first Labview solution 😄
(5,776 Views)
