Print picture
Hello!
I need help with printing pictures in LabView. I would like to print a picture across the width of the sheet without white edge on the right side. For some reason when I print, the right side increased and the picture does not cover the entire width of the sheet.
If anyone knows what is the problem, ask for help.
Greetings
E
(4,082 Views)
This is my example .vi and print .pdf
Greetings
E
(4,029 Views)
Hi asdffff,
I use for printing the method Quick Print with Visible Portion of Front Panel. It usually gives better results. Look at the print_tmp_MOD.vi.
Printing from LV is not easy. If you need more advanced reports, I would advise you to use Diadem.
With Regards,
Jiri Keprt
Application Engineer
NIE Czech Republic
CLA, CTA
(4,007 Views)
Hi FredyCz,
Thank you for help, but I use LabView v.8.6, and can't open print_tmp_MOD.vi, please convert this .vi in version 8.6.
With Regards,
E
(3,989 Views)
Hi X_man,
here is the converted vi.
Jiri Keprt
NIE Czech Republic
CLA, CTA
(3,979 Views)
Thank you.
E
(3,950 Views)
