Print function causes VI to hang.
I am running two VIs concurrently one is an "operator screen" and one is a "test screen".
When I print the front panel of the test screen using the "Print Panel.vi" all VIs will hang for about 1 to 3 seconds.
This interuppts the data flow on the other VIs.
Is there a way to eliminate this interuption?
See attached example
Labview 6.1
3Ghz, 1Gb
(2,786 Views)
Perhaps if the two VIs were running in different threads? Can't say for sure because you only posted one VI and that VI was missing all the subvis so I couldn't run the example.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,774 Views)
I can duplicate this problem in just the example attached above.
If you press the print button at the bottom of the VI while it's running, the front panel will hang for a second or two.
I need to be able to eliminate this hang time, if possible.
(2,755 Views)
Unfortunately, as I said above I can't run the examloe because all the subvis are missing.
Mike...
LabVIEW Champion
(2,752 Views)
Sorry, Try this one.
(2,726 Views)
