Print VI at completion, with a print dialog box??
I'm trying to print a VI at completion, and want the user to be able to choose which printer they want to print to. Is there a way I can open the print dialog box from Labview??? (I'm relatively inexperienced with the program) Thank you!
(3,177 Views)
Liz,
Try this example out. It uses the Microsoft Print Dialog Box common control via ActiveX. I based it off of another example form our web site that I found by searching for "+labview +print +dialog +example".
Randy Hoskin
http://www.ni.com/ask
(3,177 Views)
Not that I know of directly from LabVIEW. You could write a C code
wrapper DLL that calls COMMDLG.DLL (the windows common dialog API
calls) to give you the print dialog, or could write write an MFC DLL
that uses a CPrintDialog.
If you use MFC, then you will be writing C++ and will have to make
sure to watch out for "decorated" names by by using the extern "C"{ }
declaration around your function and explicitly declaring your
function in your .def file
Douglas De Clue
LabVIEW developer
ddeclue@bellsouth.net
"Liz F." wrote in message news:<50650000000800000006540000-1027480788000@exchange.ni.com>...
> open
(3,177 Views)
