Print VI HTML cDAQ-9133 Linux RT
I have already used the VI method print HTML in a VI executed under Labview on Windows to save a HTML document in a specific location. But now, with a RT target cDAQ-9133 it doesn't work. So how can I do to save my front panel in a HTML format without going manually into print > HTML >... ?
Thank you in advance for helping guys.
(2,523 Views)
Hi cgouatarbes,
do you save the HTML in the RT target?
You surely know the RT target does NOT have access to your PC's drives!?
(2,514 Views)
Hello GerdW,
Thank you for answering me. Yes I know that and I would like to know how I can do to save my VI front panel in HTML on the PC ? Is there a solution ?
I know that it's possile to build a VI running on my PC which take the data of my RT target but I don't how to do that.
(2,491 Views)
Hi cg,
first save the html on the rt target, then transfer the file to your pc...
LabVIEW comes with a lot of examples, also projects with host-target communication!
(2,487 Views)
