Print Report problems
I made an executable from several vi's. my problem is that when i try to print a report following error-message appears:
error: -2147221164 not registered in prind report.vi
as path for the printer i have nothing connected so i use the standard windows printer...
(3,181 Views)
Here is the link to a Knowledgebase. It talks about the exact same error,
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/9acb175f6de483ae86256b2200776b8b?OpenDocument
Hope this helps,
Shruti T
(3,181 Views)
hey there! sounds good this soloution. an it is really the problem i think. if i login as an administrator on w2k the report vi's do work fine. but if i hanven't administrator rigths they won't work.
if i type in regsvr32 C:\prgram Files\......
there returns a dialogbox with this content: LoadLibrary("C:\Program Files\....") failed the called module was not found
but i have veryfied that this dll is in the rigth directory
(3,181 Views)
