Print HTML FILE
Hi all :
I save a HTML FILE ,, I want to print this file from labview ,, how can I do that
thanks
Message 1 of 12
(4,623 Views)
Hi elyan,
you can use the "Print HTML Report.vi" , it is part of the "Print Report.vi". You mean the report which is already saved, right?
Mike
Message 2 of 12
(4,620 Views)
here
Message Edited by mathan on 06-03-2008 07:17 AM
Message 3 of 12
(4,612 Views)
Hi
where can i found this ,,
I build vi ,, please see attach  what I am doing wrong ??
Message 4 of 12
(4,610 Views)
Hi
Message 5 of 12
(4,607 Views)
Hi elyan,
do you want to print the file after you have saved it, or do you make both, save and print at the same time?
Mike
Message 6 of 12
(4,604 Views)
Hi mike :
i want to print the file after save it,,
Message 7 of 12
(4,600 Views)
Hi elyan,
see the attached picture please. Change your "Print HTML Report.vi" in the same way and save it with a new name.
Hope it helps.
Mike
Message Edited by MikeS81 on 06-03-2008 02:31 PM
Message 8 of 12
(4,598 Views)
Hi Mike :
Sorry that I am asking so lot ,, but I don,t know how to Change "Print HTML Report.vi" in the same way and save it with a new name. i am using labview 8.5 I don,t see "print HTML Report.vi", I have "print report.vi "only
Who  can I change it  ?? can you explain or send
thank alot
Message 9 of 12
(4,594 Views)
Hi elyan,
if you use 8.5, you can use the attachment.
Hope it helps.
Mike
Message 10 of 12
(4,568 Views)
