Print Error when recompiling in LV2010
I had a working executable that was built using LV version 9.0.  When I recompiled and built the executable using LV version 2010, I get an error #7 when I try to print my results in LV.  Please see the attachments.
Thanks in advance.
(2,500 Views)
You should really use the Code Capture Tool (link in my signature) to share your code online; almost nobody is going to open a .docx file in a forum.  I wouldn't trust anyone that much unless they sat right next to me at work. 😉
Jim
(2,492 Views)
Hi VI Joe,
As we just discussed, check out the "Error 7 When Running an Application Using VIs from Report Generation Toolkit for MS Office" KnowledgeBase article, and see if that solves the problem.
http://digital.ni.com/public.nsf/allkb/8A0E6274D9BD7B1986256F62006AD402
Andy H.
(2,487 Views)
