Preview Image Not Shown (Vision Development Module)
Does anyone know why I am not able to see my preview corrected image after I have created a calibration setting? I have tried to check the "Preview Corrected Image" box, but after I click "Ok," The image goes back to normal. I have attached some images of my results. Is there anyway I can view the corrected image while I continue to process the image?
Thank you
(1,731 Views)
Interesting pictures.  Don't know what you did, don't know what you are showing us.  If you are having a problem with LabVIEW code (which reside if files with the extension .vi, but not in files with the extension .png, snippets don't count when serious debugging is required), then you need to attach your VIs.
(1,690 Views)
Hello Bob,
I have posted the .vi file and the image I am trying to calibrate.
The project I am working on involves a rotating bucket with a USB3 camera that will be triggered by the rotating motor to capture images. It will take pictures every certain motor degree and stitch all images together to form a panoramic picture. In the script given, my plan is to calibrate the image and mask out a single band then record the X-resolution length of that masked image. I have yet to include this Express VI into LabVIEW because I would like to get the calibration finalized.
I just need guidance or help on how to preview the corrected image to be able to mask a single band.
(1,658 Views)
