Prevent Scaling of objects/indicators on FP
Do you know of anyway to prevent the scaling of certain
objects/indicators/controls when the FP is resized?
The bounds property node can only be read rather than written to and
position property only deals with left and top coordinates.
I am bit stuck. Any ideas.
Cheers for the help in advance.
Nick 🙂
(2,512 Views)
In the File menu
Vi Properties
select Window Size in the Category: drop down list
Uncheck the box next to
Scale all objects on front panel as window resizes
Also you can uncheck the box
allow user to resize
in the Window appearance selection Category: under
customize
Hope this helps!
Gold
(2,512 Views)
