Pressure transducers/transmitters that are compatible with the NI 9237 DAQ C Series Strain/Bridge Input Module
Hello everyone. I am trying to use a pressure transducer/transmitter with an NI 9237 DAQ. It is my understanding that only ratiometric sensors will work with this system (at least with the integrated power supply). Is this accurate? If it is accurate, then will any ratiometric pressure sensor that is powered by ~5V and outputs ~0.5V-4.5V work?
For example, this sensor: https://www.newark.com/honeywell/px3an2bs100paaax/pressure-transducer-100psi-1-8/dp/78Y6221
Thanks!
Message 1 of 1
(1,071 Views)
