Pressure sensor
I will be using a  pressure transducer with analogue output of 0-5V for a project with school , I also have a a usb 6009 DAQ and will be using labview, I am asking for help on how to connect sensor to daq and how record results on labview software please ( no Experence on labview)
(2,031 Views)
Start with the example finder.
Search for Voltage.  You'll see some code to get you started.
Patrick Allen: FunctionalityUnlimited.ca
(2,015 Views)
Okat thank you, and what about the wiring?
(1,975 Views)
The manual for the DAQ 6009 will show you.  Probably as simple as the + side to AI0 and the - side to GND, or common.
https://www.ni.com/pdf/manuals/371303n.pdf
(1,969 Views)
Hi alm,
MAX (or the DAQAssistent) will also tell you…
(1,943 Views)
