07-11-2020 12:02 PM
Hello
I have a pressure sensor that goes from -1 to 6 bar. And returns 0 to 10 V. So 10 V = 6 bar and 0 = -1.
Problem, at atmospheric pressure it returns 5 Volt. So this is wrong.
I just openned the DAQ assistant (input => voltage) and returns the value "data" the DAQ assistant delivers. I set Continuous Values because I want to have the continous values. I set 100 Hz because I don't need so much values every second (and also 1000 Hz bug).
Has somebody an idea what could go wrong. Can it be the software or in the Labview side ?
does calibration works ?
thanks
07-11-2020 12:51 PM - edited 07-11-2020 12:52 PM
Can you repeat your question with a bit more detail?
