Pressure Sensor Triggering String
I'm working on a project where we are trying to send a string via bluetooth when a pressure sensor is triggered for at least two seconds.  We have a crude version where it runs continuously and resets after a certain amount of time but it just has placeholder empty strings when the sensor is not being triggered, as seen in the attached zip folder, with the file we're looking to run being the MAIN_test.vi file.  We're wondering how we can only have it send the one message when the pressure sensor is triggered for long enough and just remain idle when it is not triggered.
Thank you for any help!
(1,742 Views)
Just add a case structure and wire it to the condition that tells you whether to send message or not
Santhosh
Soliton Technologies
(1,729 Views)
Can you send a picture of what the false condition would look like?
Thanks!
(1,647 Views)
