Pressing escape exits two button dialog
I have a Two Button Dialog that I am using to ask for the type of test being done.  I would like to disable the ability to skip the dialog pop-up if the user is holding the escape key.  Is there a way to do this?
Thank you,
(2,776 Views)
Accepted by topic author M. Bobby
It seems you want to remove the >esc> key navigation assignment from the dialog box.
Simply create your own dialog box (a simple subVI with a few buttons) and assign the key navigation the way you want it
(Right-click...advanced..key navigation).
(e.g. don't assign the escape key to the cancel button)
(2,765 Views)
You can get started with the template "Dialog using events".
(2,759 Views)
