Press button hidden by image
JoVMo
Active Participant
How can I use a button that is laying under an image?
5 REPLIES 5
johnsold
Knight of NI
Re: Press button hidden by image
Make the button transparent and put it in front of the image.
Lynn
Knight of NI
Hi Jo,
you can't unless you move the button on top of that image...
Maybe you should explain what you gonna do?
Knight of NI
... or, you could respond to a click event on the image (I'm assuming you're using a picture indicator), get the coordinates, find out if they're within the rectangle of the button, and then trigger the button's click event.
Sounds to me like Lynn's suggestion is far easier.
Olivier_L
Active Participant
... or you can also customize a button with your image. Even having two images depending if button is pressed or not.
Olivier L. | Certified LabVIEW Developer
JoVMo
Active Participant
I try the transparent button. Tnx!
