Preferred execution system
What is the exact meaning of:
User interface (I know)
Standard ?
Instrument IO ?
Data acquisition ?
Other 1 ???
Other 2 ???
Same as caller (I know)
I know that it also depend on if your computer is a Single or Dual Processor
Thanks!
Nitrof
(7,865 Views)
I may be wrong, but I think the five available execution systems are basically identical (i.e. the Data acqusition system is not any more optimized for DAQ operations than the instrument IO system e.g.), NI has just assigned different names for them to make it easier to remember/automatically associate with the right/consistent parts of your code...Unless anything else is defined the VIs will run in the standard execution system. Keeping time-critical/consuming parts of your code away from the UI is always a good start...
Greg McKaskle has written several good answers about execution systems:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000037740000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=difference+
between+execution+systems&USEARCHCONTEXT_QUESTION_S=0
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000004410000&ECategory=LabVIEW.LabVIEW+General
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000002E2F0000&ECategory=LabVIEW.LabVIEW+General
(7,865 Views)
> http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101...
http://exchange.ni.com has been obsoleted by http://forums.ni.com/ni/ . I'm not sure how to find those three documents, but I found the following...
1999: priority of VIs
http://forums.ni.com/ni/board/message?board.id=170&message.id=5587
2001: Need some clarification on Execution Systems, Priorities, and threads with Labview on Windows NT
http://forums.ni.com/ni/board/message?board.id=170&thread.id=11944
2002: Multithreading in LabView loops doesn't work?
http://forums.ni.com/ni/board/message?board.id=170&message.id=23498&requireLogin=False
2002: best way to do parallel activities
http://forums.ni.com/ni/board/message?board.id=170&thread.id=24932
2003: Is this roughly how the labVIEW Execution Systems work?
http://forums.ni.com/ni/board/message?board.id=170&thread.id=45194
Is there anything more current?
(7,248 Views)
