Powering multiple Devices using PS-15
I have PS-15 (Qty:5) and Crio-9046 (Qty:1), Crio-9145 (Qty:4) and SLSC-12001 Chassis (Qty: 1) So a Total of 5 power supplies and 6 Chassis, I am not sure how to do the power distribution. Can I use a single PS-15 to power multiple Chasis?
(1,114 Views)
Hi linu,
Ask an electrician working in your lab!
That being said: the PS-15 provides 24V/120W as specified.
Now you need to determine the power requirements of your devices to decide how many devices one PS-15 can supply…
The SLSC chassis might be tricky as it is specified with a range of 45W to 720W…
(1,112 Views)
Hi I am using SLSC-12001 Chassis with FIU-12251 (Qty: 4) and FIU-12252 (Qty: 1) and SET-1215 (Qty: 1)
As per the datasheet maximum current requirement with modules is 720W
However, it also states that the startup current could be significantly higher.
What is the recommended power supply for SLSC-12001?
I am also unable to create SLSC configurations on NI Advisor.
(1,023 Views)
