Powerflex 755 Communication
Hello all,
I am a mechanincal engineering student at Milwaukee School of Engineering.  I am building up a dyno system to test small engines.  We are going to do our data aquisition and control with LabView.  Our dyno is a 20 HP electric motor coupled to an Allen Bradely Powerflex 755 motor drive.
How can we establish communication between the drive and LabView?  The drive communicates using either Allen Bradely's Eithernet/IP Protocal, rs-232, ect, or analog inputs and outputs.  Ideally we would use the eithernet connection.  Has anybody written any LabView code to comunicate with Eithernet/IP?  If not where should we start?
Thanks in advance for your help!
Adam
Message 1 of 14
(5,914 Views)
You can use VISA to read and write to your device over Ethernet.
Can you see your device in MAX?
Have you read this?
http://zone.ni.com/devzone/cda/tut/p/id/3325
Omar
Omar
Message 2 of 14
(5,908 Views)
Thanks for the link!  I am reading up right now.
Adam
Message 3 of 14
(5,900 Views)
OK. So far I have been able to successfully "ping" the motor drive.
I am having trouble creating a new device.  When I go to create a new device the only option in the wizzard I have to choose from is "Devices and Interfaces"
Message 4 of 14
(5,893 Views)
Could there be a module that i am missing or some kind of software error that is preventing me from being able to successfully create this VISA device?
Adam
Message 5 of 14
(5,885 Views)
In MAX, do you not see the "Create New..." options from a right clik on "Device and Interfaces" or the "Create New..." button at the top?
Omar
Message 6 of 14
(5,879 Views)
Yes.  I see create new, I click it, and the next dialog box doesn't seem to be working.
Message 7 of 14
(5,873 Views)
Can you post a PNG of the dialog box that doesn't seem to be working?
Omar
Message 8 of 14
(5,864 Views)
Good idea.  We are updating some of the software. If that doesn't fix the problem, I'll post a picture tomorrow.
Thanks again.  I appreciate the help.
I like this forum.  I get a kick out of the fact that the newbie's icon is a car with a really big spoiler.
Message 9 of 14
(5,836 Views)
I was able to create a VISA TCP/IP resource for the Powerflex.  It doen't seem like its working though.  When I click "open VISA test pannel"  I get this error message:
Any idea what might cause this?
Adam
Message 10 of 14
(5,817 Views)
