Power supply
Hi i need to connect via labview to a power supply Sorensen or XTR 20-42 any chance anyone in here can help me with that im new in using labview if you can do it will be awesome.
Regards
Sergio
(2,484 Views)
The vendor has an IVI driver (see Types of Instrument Drivers) as well as the USB driver. The USB driver makes it appear as a serial port. Is that what you have or is it GPIB or Ethernet?
In any case, I did not use the IVI driver. I wrote a LabVIEW driver and for information on how to do that, there is a section on the main Instrument Driver Network. Personally, I think creating a LabVIEW driver for a power supply is pretty simple but then I've been doing it for quite a few years and I'm not a big fan of IVI. You might want to give the IVI driver a try.
And no, I cannot provide the code for the LabVIEW driver. Sorry.
(2,479 Views)
