Power management
I'm considering adding a UPS to my system to prevent from power down. I
don't know whether LabVIEW has some way to manage the power, such as
knowing that it's running on battery power so we can let the program
shut down itself if the power down lasts for too long.
Thank you in advance,
Guangde Wang
Message 1 of 10
(4,752 Views)
> Guangde Wang
What you really need is to look for UPS that have some
sort of monitoring port (serial , USB, whatever). Most of the better
models have this. Then you can program in LabVIEW to check
if the power is out, set a wait time, check again and power down if
necessary.
Kevin Kent
Message 2 of 10
(4,751 Views)
Thank you both for help. I'm using a desk top and it needs to work over night
without any one to attend it, that's why I want to add this safety procedure.
I think the key is whether LabView can tell whether the coputer is on battery
power. I suppose that the UPS will send some signal to the corresponding port
then use LabVIEW to check this port. Is this the way?
Thank you again for help,
Guangde Wang
> > Guangde Wang
> necessary.
> Kevin Kent
Message 4 of 10
(4,751 Views)
Yes I beleive this is the solution you are looking for.
Get a UPS that has a serial port and hook it to the serial
port of the PC. You should be able to check it from there.
Kevin
> Guangde Wang
own. I
> > > Guangde Wang
> > necessary.
> > Kevin Kent
Message 5 of 10
(4,751 Views)
It's not a complete solution though- most serial UPSs come with drivers that
hook into Windows so the OS knows what state the power supply is, and can
shut down gracefully when the UPS battery expires.
To be able to access the serial port via Labview and poll the UPS directly,
you have to disable this driver, I think- otherwise you can't get at the
serial port that's in use by the UPS driver. This means the Labview software
will be aware of the problem, but the rest of the system no longer will be.
I guess as a bodge you can exec the "shutdown" command shipped with the NT
reskit while the Labview stuff is exiting- this can at least force all other
applications to close and then shut down the system, but there should be a
more elegant way
of hooking into the OS for this!
I've just had a look at my UPS software- an APC SmartUPS1000, and discovered
that in the configuration are all the actions to take place on certain
events, like loss of mains power and the low battery warning. As well as the
standard loggings and notification options you can also specify an
executable to run. Looks like for this brand of UPS at least it would be
simplest to have a set of Labview VIs that, when loaded, automatically run,
send a message to the main application informing it of the event and then
quit, and have the UPS software call these.
Kevin B. Kent wrote in message
news:3A562527.55A90BEC@usa.alcatel.com...
> Kevin
> Guangde Wang wrote:
Message 6 of 10
(4,751 Views)
You are absolutely correct. I made some assumptions based on seeing
this thread before. Also based on a later posting in another thread from the
same person I think we may be putting the horse before the cart.
> that
> directly,
> software
m no longer will
> be.
> other
> more elegant way of hooking into the OS for this!
> discovered
> the
> run,
> > Guangde Wang wrote:
Kevin Kent
Message 7 of 10
(4,751 Views)
I have solved similar problem in my application with APC SmartUPS.
The communication between LabVIEW and UPS was done with simple "semaphore"
files
(I have configured UPS software to run batch files on certain actions).
Bojan
"Craig Graham" wrote in message
news:3a562ad5@newsgroups.ni.com...
that
directly,
software
be.
other
discovered
the
run,
> > Kevin
> > Guangde Wang wrote:
Message 8 of 10
(4,752 Views)
>prevent from power down. I don't know
>power, such as knowing that it's running on
>battery power so we can let the program shut
>long.
>Guangde Wang
If you use a laptop computer, when AC down,
it'll switch to battery automatically. And
it's easy to find out if it's on battery,
and how much power left.
George
Message 3 of 10
(4,751 Views)
Has anyone been able to come up with some code to interface between the APC products and Labview? I have not been able to get this to work. Here are the guidelines that APC sent me. Thanks Chris
http://eu1.networkupstools.org/protocols/apcsmart.html
Message 9 of 10
(4,728 Views)
Hi, Bullet. Have you succeeded in communicating with the APC UPS?
I got an APC Back-Ups 500 and I need to communicate with it through serial (LabVIEW realtime). The UPS comes with an USB cable, but there is an alternative serial cable. I've been looking for information from APC, but have found nothing.
Thank you,
Daniel
Message 10 of 10
(4,599 Views)
