Power factor, reactive, active and apparent power
Two sources for powerfactor :
http://www.zes.com/download/zes_applicat_105_leistungsmessung_e.pdf
http://www.onsemi.com/pub_link/Collateral/HBD853-D.PDF
You will need more math 😉
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 14
(1,293 Views)
And for your scale problem: It's not possible to change the numerical scale in the manner you showed. However you can create your scale if you write your own (ASCII) tics or turn of the scale and use the labeling tool.
Henrik
LV since v3.1
Message 12 of 14
(1,292 Views)
Hello guys..
i am trying measure the active power of a induction motor and i am not getting the values that i expect to, the motor works at 50Hz and i'm already acquiring the voltages and current waves and thoses wave seems to be quite right but i'm getting troubles to use the integral block at "dt" input.
I've seen some examples that multiplies the number of iterations by the number of of samples per iteration, inverts the result and puts this into the input "dt". I am not getting reasonable results with this method, if some one could give me an idea how to fix this problem it would be great.
Mário Silva
Message 13 of 14
(1,176 Views)
The dt should be the sample period.  If you are sampling the voltage and current waveforms at 500 samples per second (on each waveform), then dt = 1/fs = 2 ms.
Lynn
Message 14 of 14
(1,163 Views)
