Possible?
Hi, is it possible to display jpeg pictures without using the database? such as providing a path for the picture. i cant seem to display the jpeg picture when i used the build path with read from jpeg. Thanks for reading.
(3,258 Views)
I don't know what "database" you are referring to, but yes, you can display a JPEG easily enough.
 Use READ JPEG FILE from the GRAPHICS and SOUND | GRAPHICS FORMAT palette
Feed the IMAGE DATA to the DRAW FLATTENED PIXMAP in the GRAPHICS and SOUND | PICTURE FUNCTIONS palette.
Feed the PICTURE output into a PICTURE indicator.
You'll have to extract the size info and set the picture indicator's size to match, but that's not hard.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,248 Views)
Hi, Thanks for the guidance. i wonder if this is possible with gif files. i tried all the 3 file format but none could work with gif files. do you mind telling me how i could extract size info & making the picture box match?
(3,205 Views)
I don't know why, but GIF files are not directly supported by LabVIEW.
Take a look at reply #16 of this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=150798
There's a program called TerraView, which I mentored, and my apprentice at the time wrote.
It used a library dealing with QuickTime to decode GIF images from Terraserver and display them.
I don't remember the details now, but they're in there somewhere.
 As far as the other things, try this:
What have you tried?
Steve Bird
Culverson.com
LinkedIn
(3,201 Views)
