Possible DateTime bug in Database Toolkit
Hi!
I dont have the database toolkit here, and it seems you cannot download a 64-bit evaluation ...
Bug?  I've been writing DateTime fields to a database through the proper use of clusters and Inserts, but it seems i never get any fractional seconds. The datetime controls shows them and the database fields should support them (atleast it's showing .000 at the end) so i'm wondering: Does it somehow use regional settings for time so it's using my decimal comma and thus ditching the fractions?
/Yamaeda
Qestit Systems
Certified-LabVIEW-Developer
Message 1 of 24
(4,496 Views)
This sounds familliar. It is important to note that Time (civil time of day, NOT an SI Second) can be represtented in several ways.  LabVIEW uses a "Epoch" (0) meaning midnight Jan 1 1904 UTC and scale of 1 = 1 sec.  Excel uses a scale of 1 = 1 day and an epoch of midnight Jan 0th 1900 Local Time.  Some Data base fields may only store strings like "3/27/2011 09:56:12.098"
Converting a LabVIEW Timestamp to a value for use elsewhere isnt too tricky as long as you know the epoch and scale of the useing application.  I posted a sample a while ago that converts a timestamp to Excel format.  It can serve as an example of how these conversions are done.
"Should be" isn't "Is" -Jay
Message 2 of 24
(4,490 Views)
To debug this, I would try to isolate the problem a bit more to find out where it is ocurring.  Assuming you have the code, I would drill down into the subVIs to view the actual INSERT statement that is being sent.  For example,
     INSERT INTO tablename (column1, column2) VALUES (xyz, '2010.12.11 11:11:11.1234')
That would allow you to confirm how LV is formatting the statement string.
If that is not possible, you could try creating a "trace" on your database server to view the actual INSERT statement.
My guess is that you are correct:  That its some kind of truncatoin issue due to localization of the decimal point.  I am guessing there are ways to get around this ... both on the client side (in your LV code) and on the database side.  Best of luck to you!
http://www.medicollector.com
Message 3 of 24
(4,487 Views)
What database server and version?
Rolf Kalbermatter  My Blog
Message 4 of 24
(4,480 Views)
MS SQL Server, 2000, 2003 and 2008 i think (depending on which computer i run it on).
I'll try to look at it tomorrow at work.
The point ofc being that i shouldn't need to format time through a string manually and the like if i use a Cluster with a datetime field as Insert input.
/Y
Qestit Systems
Message 5 of 24
(4,453 Views)
Epoch--- Scale.  "Time" is a number- strings can repesent numbers BUT,.. can't be numbers
Message 6 of 24
(4,439 Views)
Well the SQL-command is a string in the end, however you turn it. 🙂
I send a datetime value, LV converts it to a string to send it as a SQL-command and SQL server converts it back to a datetime value for storage. If there's a bug in Lv's conversion i could generate that string manually and send it to the DateTime DB-field, but i really shouldn't have to.
/Y
Qestit Systems
Message 7 of 24
(4,426 Views)
Actually if you do a parametrized insert there is not necessarily any string involved. The datatime value could be directly passed as a DB variant. But I'm not sure what the internal LabVIEW conversion from it's native control datatypes to a variant does.
Another idea might be a mismatch with the used decimal character. Some local settings use decimal comma, others use decimal point. ADO, which is used by the Database Toolkit, has a strong preference to use  the local decimal format, and so does LabVIEW, unless you disable that with an INI file setting. But if your server uses a different setting you have a problem!
Message 8 of 24
(4,424 Views)
I just checked the code: DB Tools Generate Parameters doesn't use the fractional seconds at all, no wonder it didn't make it to the DB ... So, how should one go about now, i can fix it locally, but if i need to reinstall i'll bet i've forgotten i ever did the change. 😄
/Y
Qestit Systems
Message 9 of 24
(4,418 Views)
You could build and format your own INSERT statement that using this VI.  Then you could take account of the fractional seconds properly.
That sounds like a bug in your software development methodology.  🙂
Message 10 of 24
(4,415 Views)
