Positive & NEgative Transition
Hello Experts..
Please give me the solution for following problem.
Make the LED ON at a particular value while increasing the variable. But i would like to switch it off while decreasing the variable at some other value.
Lets Consider like this .... Varying the knob ranged 0 to 10units. while increasing at 5th unit the Led shd glow. but it shd go off while decreasing at 7th unit. It should not go off when it reaches 7th unit while increasing.
(2,904 Views)
See if this is what you want. When the knob hits 5 and the value is increasing the indicator will light up, when the value is falling but still above 7 the indicator will ignite until it crosses below 7.
Hopefully this helps.
-Dave
(2,899 Views)
